87 chaparral 187 leaking
Davidcarr87
ok, you seen the boat i have.....it was taking on a lot of water....so i had my dad back the boat in the water on the trailer and i was lookign to see where it was coming from......couldnt tell to good...so we came home and put the hose inside the boat in the area it was coming in...and it wound up that the prev owner put caulk where the outdrive meets the boat....and the caulk came off on the bottom so it is leaking.....how hard is it to change the seal??...i am going to order a manual tomorrow...
Re: 87 chaparral 187 leaking
To replace that seal, all you have to do is remove the drive, remove the engine, take off the exhaust tube, disconnect the steering, and remove the transom shield (aka gimbal housing).
Normally, the seal isn't the major cause of the leak, the reason it leaks is the transom is rotted and the transom sheild holding nuts have nothing to tighten against.
Have no clue as to what engine and drive combination you have.
Davidcarr87
nice, lol....like i said, im going to order the owner manual tomorrow....so that should walk me threw it a little bit better
Ayuh,.....
Then you can wander on down to the Restoration Forum,.....
All the Answers to How to Repair the Hull down there...........;)
Davidcarr87
well its been 2 years, had a divorce..and moved several times..never did anything with the boat..so now its time to get started on it..:D
whew where to start now..
