nola mike
- Joined
- Apr 22, 2009
- Messages
- 5,857
1. Timing light on either the coil wire or any plug will give you an idea (obviously if it's on one plug wire it only shows that the module/distributer is firing that plug)
2. Wh/r wire is hot with ignition on
3. Just check the voltage at the end of the pigtails
4. If no spark with the timing light, electric is your issue. If there is a spark you'll need to run some confirmatory tests. In line spark tester is more accurate since it tells you if the voltage is strong enough to bridge the plug gap. Theoretically you need to check it at every plug.
