'88 Yamaha Tach Wiring Colors??
wood2turn
I have an '88 Yamaha CV85 2-stroke.
After all these years I'm finally going to add a tach to the dash. But I don't know the wiriing color codes...Can anybody fill me in?
I think it's the 3 wires that are deadended in the harness at the control box but I still don't know which is which...except for ground.
ANY help would be appreciated,
Thanks,
Terry B.
99yam40
Re: '88 Yamaha Tach Wiring Colors??
I am not sure about 1988 models but,Yamaha tach signal is normally green, Switched power is yellow. Back is ground, and Red is 12v positive not switched.
wood2turn
SUCCESS!!!!!
You are correct '99. But I did it before reading your post. I located the color codes online and went with them.
Thanks, Terry B.
cwhitlock
Does anybody know what the green wire inside the motor connects too?
