89 85HP Tilt Relays
shildreth
Can anyone one send me a picture of where and how the tilt and trim relays mount inside the motor
Re: 89 85HP Tilt Relays
On my 70hp, they are plugged into the wiring harness, then zip tied, out of the way on the port side of the motor.
BigD
Follow the wires coming from the tilt motor into the motor, they should be right there. I also have the 70hp and mine are on the right front engine case when you are looking at the front of the motor.
