89 Force 50 Water Pump
middleton1
I've been trying to get a water pump or a water pump kit for my '89 Force 50 for sometime. No decent Mercury dealers in the area and no one will work on a Force that old. The problem I'm having is that the NAPA catalog and online catalogs have impellers listed for 80-87 and 92-99, but years 88-91 are listed as N/A. I can't believe that this part would not be available. Can someone help me out here?
Re: 89 Force 50 Water Pump
For Mercury and Force parts:<br /><br /> http://www.mercurypartsexpress.com/PartsExpress/ProductSelection/ServiceParts/sphome.asp?CID= <br /><br />You can type in your serial number and follow the links, gearhousing section, waterpump kit....<br /><br />Or you can type in the part number you need.<br /><br />Waterpump kit FK1073 $61.65<br />Impeller F433065-2 $12.70<br /><br /> I found the part numbers here: http://www.mercruiserparts.com/selectModels2.asp?type_id=FORC
jasonbailey
go to www.fairwindsmarina.com Get the phone # and call them with your model and serial #. They will either have it in stock or be able to get it very quickly.
