90 HP Tilt Trim Unit Compatability 1990 vs 2002
midsized johnson
Probably a dumb question, but is this even a possibility? I found one off the 2002 and wonder how different it is from the one on my 1990 model.
Thanks in advance.
99yam40
if they are the same part # in the parts catalog, they are the same.
look them up to see
midsized johnson
I bought it, so as soon as it's in hand, I'll be able to check for fit. Will update if anyone is interested.
midsized johnson
In case anyone is interested, the '02 TT unit fit the '90 year model perfectly. The only difference is the relay as the old one is a 3 wire motor vs 2 wire in the newer motor.
