9000 ft altitude jetting
71cudaman
i need to know what size high and low speed jets i need for a 1990 60 hp Johnson triple that I will be using at 9000 ft altitude
about 27% smaller than you have at sea level. you also need about 27% less pitch. (you are loosing 3% per 1000 feet of elevation)
greggilo
Curious where would one find different size jets? I moved to 5600 elevation and did not change jets. Engine probably would run better?
71cudaman
Jet's are available for my 60 HP Johnson from a dealer for OMC. Or so I have been told
Gregger----Do you have a 2 hp or 300 hp.----And is it black / white / or blue ?---Yes a good dealer can help you.----The 24 year old clerk at AMAZON can not !
71cudaman
I have been told that there is an OMC technical bulletin # 2217 that has high altitude jet information. I have a copy for 85 HP to 235 HP. I need the page that shows 60 HP.
Well----See your friendly dealer.----Buy a jug of oil.----Then they will help you !!
