90hp to 140hp....can it be done?
gregr1971
i have a 1989 88spl that runs great, and a 1982 140hp that i overheated and seized. can i pull the powerhead from the 88spl, add the carbs and exhaust plates from the 140, put back on the 140 midsection and have a 140? the 140 mid and lower are in MUCH better shape.
i cant completley remember, but i THINK the 140 has more agressive port timing.??
Dhadley
Re: 90hp to 140hp....can it be done?
The port timing and port area are different but you can convert the 88 porting to the early 140 / late 115 porting.
gregr1971
please explain the procedure.
i may not have an'89?? my model# is J88MSLCUC what year is this exactly?
my 140 model # is E140TRLCIH .
gregr1971
Ok, Its An '87 , 88spl.
My 140 Is An '81.
Faztbullet
Trying to DIY porting is not recommended as it is better done by a marine machinist.
tashasdaddy
it is more complicated than you think, you could end up with 2 dead motors.
