92 90HP Force water pump and impeller kit
dcar00
Hi all,
I am going to change my water pump and impeller on my 92 90HP Force
Do I need both the water pump kit and impeller kit or does the water pump kit encompass both?
Can anyone point me to the correct part number for them?
I assume I don't need to change the water pump housing unless it looks damaged when I drop the lower unit.
Thanks
dcar00
Re: 92 90HP Force water pump and impeller kit
water pump kit includes housing cover and o-rings, gaskets, impeller, and other parts.
No need to buy the whole kit if you only need the impeller.
Mercury part number 47-803631T $30
Generic impeller part number found on the web, 18-3017 or just 3017.$16-$20
dcar00
Thanks Roscoe,
I think I may replace the whole water pump as I am getting the over heat sensor and I want to take anything to do with the water pump out of the equation.
Is FK1204-1 the right number for the water pump?
thanks
dcar00
