92 Johnson 120 Fuel Pumo
I have seen people talk about a VRO pump conversion to run oil in the fuel in the tank. I called my local dealer and they did not know what it was. Does anyone have a Johnson part number. My motor is a Johnson 120tlamd
Thanks
Cortes100
Re: 92 Johnson 120 Fuel Pumo
I disconnected the VRO on my motor a year ago. It's a simple procedure which you can find in the link from the previous post. Won't cost a cent and it will work just fine.
I had to disconnect mine to eliminate other problems I was having. Eventually I will get the newest version and and reconnect the oil pump again. Just be prepared that you will need to mix gas/oil everytime you fill up. It's a pain in the a**, but at least I know it's getting oil.
