92 mercruiser 4.3l 6t2 no spark
Bt Doctur
You should be able to drop a standard dist in there and get it wired correctly
Kelsonj
So I'm gonna do a few tests to make sure the computer is functioning then more than likely grab the 4.3L Delco Voyager EST Marine Electronic Distributor Kit. It will cost less than an of the obsolete parts that I would need to replace. It seems to come with everything need for the swap.
Rick Stephens
I went to the EST when I ended up with a faulty Mercruiser Thunderbolt IV module. Easy installation and cheap to repair. Best part, darn near common as dirt, so not likely to become an obsolescence hazard later.
