- Joined
- Jul 23, 2011
- Messages
- 52,521
you have an AQ drive. remove the 6 bolts from the clamp ring that holds the donut around the PDS to the transom shield, put 3 of the bolts into the 3 threaded holes and jack it off
undo the battery cables, and the grounds at the back of the block
next undo the bonding wires
next undo the exhaust hoses
undo the supply hose to the raw water pump, unclip it at the back of the block
next undo the fuel line and plug
next undo the throttle cable
next undo the trapezoidal harness plug
next undo the two front motor mounts
now hook up your chainfall/hoist.... lift a bit, slide the motor forward to pull the PDS out of the transom shield
should take you 30 minutes total once you have the drive off on an AQ series installation.
