94 90 hp tilt problem
trophyforce
just got a new pump assembly from northern marine, put pump assembly on motor, connected the 4 lines to the bottom of the pump , filled res. with fluid. tried bleeding it for 2 hours with no results . the shaft that drives the pump is spinning. it seems like the pump is not pushing the fluid through the lines because the pump is always full of fluid. if i disconnect one of the lines at the bottom of the pump it pushes fluid out. any info would be great.
jerryjerry05
Re: 94 90 hp tilt problem
Make sure the lines are hooked up correctly.The new pump might be defective. Is the end of the shaft connecting with pump? Jerry
