96' 3.0L Merc. carb question
jamesgreen
I Have a 3.0L 1996 Merc. Alph 1. I was pulling out the spark plugs to change them and they were black. I had troble with it idleing last year . I had the carb gasket changed and that seem to help some. should I try to adjust the carb or look some where else for the problem.
Silvertip
Re: 96' 3.0L Merc. carb question
Black sooty plugs indicates an overly rich condition. Check choke operation.
Mile-High Mariner
James:<br /><br />Put your plugs back in, put water to the outdrive (lake or muffs, either way), and remove the flame arrestor from the carb. Start the motor, rev to 1500-2000 rpm, and slowly pour or use a syringe to squirt water down the carburetor throat, pausing whenever the rpm begin to drop. Pass about a quart of water through the carb in this fashion, at varying rpms if you like. Once you've finished, stop the motor, pull the plugs and check them; they should be much cleaner - the coffee brown we strive to maintain. Congratulations! - you've not only cleaned your plugs, you've also decarbonized your pistons and much of the combustion chamber and valve surfaces.<br /><br />Make sure you take the time now to adjust your carburetor settings (lean it out, dude) in order to remedy the situation that caused the carbon build-up to begin with.<br /><br />Happy boating!
harveje
Will Seafoam do the same thing? I've never heard of the water trick, Thanks<br />P.S. Seafoam will smoke up the neighborhood.....
I use the Water Method,......<br /><br />A Soda Pop Bottle Full is Plenty,.... Just do like Dave says,....Pour it in as Fast as it'll take it,.. Without Stalling.......<br /><br />As for your Issue,.......<br />You should try Rebuilding the Carb........ If that doesn't Fix it,......<br />It might need to be Replaced.....
jamesgreen
Water into the carb? Changing the plugs I can handle. I'm not sure about this other stuff. I am trying to keep it simple and cheap.
