96 Mercury 350 will lose rpms , sputter,stall.. only to be restarted at a later time
mikethepike
On a recent trip , while on plane (3300 rpm's) trip my starboard engine lost rpms, sputtered and finally stalled about 18 miles into a 30 miles trip . I tried restarting it...but only smelled gas, so i let it be for 1/2 an hour and it restarted when i got 5 miles from my destination. I didnt find anything out of the ordinary and finding a mechanic on the wknd was impossible.
On the way back the same thing happened, i was on plane for 15 miles and the same engine sputtered, and finally died. It did restart after approximently 40 minutes and i just cruised in @ 2000 rpms back to the dock without any further problems. Normal 140-160 temp , oil and voltage all in regular perameters
Any thoughts?:facepalm:
1996 Mercurys with 500 hours
zx9rstv
Re: 96 Mercury 350 will lose rpms , sputter,stall.. only to be restarted at a later t
Sounds maybe your coil is getting too hot and killing spark. You should do a ignition system diagnosis as described in the adult section.
mikethepike
That sounds like it may be my culpret. From my understanding they are filled with oil and when it cant disapate the heat it will act erratic...ie kill the spark .
I looked in the adult section ...what # are you referring too?
Thanks for the fast response
zx9rstv
#17
Ayuh,... Got a serial #,..??
Carbed or Efi,..??
mikethepike
Sorry dont ahve a serial number handy at the moment.
It is carburated
Ayuh,... 2bbl. or 4bbl. carb,..??
zx9rstv
any update? Have you had a chance to troubleshoot?
mikethepike
Sorry, 4bbl. carb
Going down today to change the coil . Most everyone agrees this is the culprit
Heading back to Ohio ( SATURDAY) for a 30 mile trip...hopefully problem free!!! Boat U.S. has unlimited towing for $34.00...going to sign up for that as welll
mikethepike
Changed the coil in 5 minutes...ran to Maumee bay resort for the weekend at 30 mph each way for 30 miles with NO PROBLEMS!!!!!!!
Very happy too have this great forum around. Thanks Iboats!!!!
