97 Johnson 115 cracked carb bowls *Update
Jacob645
Noticed some large cracks and a little fuel coming out of my carbs. What could be causing this? Do I just need to replace the bowls? It's a V4, so I'm assuming I should go ahead and get 4?
boobie
Re: 97 Johnson 115 cracked carb bowls
Yes, replace all four of them.
Plastic is not a " permanent " material.---------Also these parts warp with time.--Then again most folks overtighten the screws as well.----Torque on these is in the order of 10 inch lbs.---------I prefer older motors with metal parts.
Jacob645
Do I need new gaskets, drain plug, o-rings, or anything else, or can I just take it all out of the old one?
You will need new gaskets.----Use ALL the parts found in the old bowl.----Torque to 10 inch lbs.
boobie
Don't just put the bowl screws in when installing the new bowl. Back them off slightly until you feel a "click" on the screw driver. This starts the screw properly into the carb body old threads.
Jacob645
So, screw through the plastic then back of til it seats correctly into the top of the carb?
MH Hawker
frozen water
Jacob645
I don't know. I keep it in the garage, and it usually doesn't freeze in there. Although it has been quite cold. Down in the teens a few times this year. So, would that mean there's water in my gas? Or condensation?
James R
There is almost always water in Ethanol gas. You should be using a water trap filter and Stabil in your fuel to help prevent the problems caused by ethanol Gas.
boobie
No. You back them off BEFORE starting them in the upper carb housing.
Jacob645
I don't have a water separator, but I always use stabil and keep the tank full.
Jacob645
Is it unsafe to operate it like this?
bob johnson
the theory of turning the carb screws backwards before tightening is based on REUSING the old plastic bowls..... you are just making sure you are NOT making NEW threads...backing off allows the screw to fall into the same pitch path it previous was in.... if you buy NEW plastic bowls...I am thinking there is NO thread there now.....so that trick isnt used. ( i have never bought new carb bowls so i am thinking this is the case..ie no threads)
I do not believe there are threads in the carburetor bowl at all !!----The threads would be in the carburetor body.
boobie
Correct.........
bob johnson
I was thinking I couldn't remember, threads in the plastic bowls......
but the reason you turn backwards is the same... so the screw falls into the old thread path....
from memory, am thinking the screws were a self tapping style.... and not standard machine crews......
bob
I believe they are standard machine screws.
boobie
They're not a machine screw. I don't know the size but they have a very course thread made for plastic.
Jacob645
Re: 97 Johnson 115 cracked carb bowls *Update
I just got done installing the carb bowls. Afterwards I pumped the bulb to make sure there were no leaks. Then I noticed fuel dripping out of the fuel filter :( Took it off to find 2 warped Orings. It was the bottom side that was warped where the gas would've sat the longest, so I rotated them 180 degrees. No more leak! Good temporary fix til I can get some Orings Monday.
Question: Is there any adjusting I needed to do with the high speed jet in the bottom of the bowl? I just screwed it in.
