'97 MCM 3.0 LX
joey nathan
Good day all,
No spark condition: coil ohms are 0.45 primary, 9,105 secondary
Can I check output of ignition amplifier with voltmeter? If so, what should I be looking for?
Did this issue just start or was there anything which shuld some kind of signs prior?
Being a 97LX and no serial number it should have EST distributor. Check the distributor
joey nathan
Just started - yes, that's the distributor, I have some checking to do
Engine Serial Number 0K 174898
joey nathan
TY alldodge, neither lead is shorted to ground and coil itself measures 952 ohms - does this mean amplifier has failed?
Check the gray wire with coil disconnected from harness, and disconnect tachometer, then to determine gray wire is not grounded. Disconnect the shift interrupter
If you get power to the coil when key is turned ON, and connections to other wires are good, then I would say it most likely is the module
joey nathan
Swapped in new module and she started straight away. $40 from O'Reilly, same part at West Marine $115
EST ignition same as 1988 Chevy Astro Van Thanks again...
