9780s Weber 4 bbl
sigkadetm
I have a 9780s weber 4 bbl on my1996 Chaparral 4.3LX Mercrusier. A 9600 Weber 4bbl should be on that engine. Will the bigger 9780s do any harm to the 4.3 LX? The 9780s came off of a V8 5.7
Ayuh,..... Welcome Aboard,.... It'll run, but it is atad big for a 4.3,.... More for BBCs,.... Even the 350 runs real well on the 9600 Weber/ 1409 Edlebrock carbs,.....
achris
More fish than mountain goat
It won't hurt it, but the engine will not be performing the way is should. The carb is too big, and at low speeds, the air velocity through the venturis is too slow to pick up the fuel correctly. You may end up with rough idling, and poor acceleration... (as well as a larger fuel bill)...
