A good Cleaner
c03camson
Im looking to find a good cleaner and or protectant for my seats and sun cushion on my boat. Im not exactly sure what the material is, i guess its either vinyl or pleather or something. Its in pretty good shape just want to get it looking good for the summer. thanks
biglurr54
Re: A good Cleaner
I use good bathroom mildew cleaner. The one I like is Clorox Mildew Cleaner. It sprays on and wipes off. I?m not sure if it will cause damage to the vinyl or not. I?m on three year of using it and not issues. Make sure when your done cleaning the vinyl you spray it with armor all or some other material moisturizer and protectant. I spray my boat down every time I put the cover on. A boater?s best friend can be Mr. Clean Magic erasers. As with all chemicals and cleaners, try them in a non conspicuous spot first. My wife used a Mr. Clean eraser on the sides of my painted aluminum boat and it made all the paint look dull because it put tons of tiny scratches in the finish.
saywhat
Re: A good Cleaner
I use mostly 303 products - the vinyl cleaner and aerospace protectant - I highly recommend both....
Re: A good Cleaner
Don't use bathroom cleaners on vinyl. The grit and bleach should be a last resort, as this will harm the vinyl. Start with boat soap or laundry soap and water. If that doesn't do it, use some Spray 9 cleaner or Castrol Superclean.
Treat all vinyl with some kind of vinyl protectant (Armorall or other stuff) after it has been cleaned. This will protect it from UV rays of the sun.
captain zac
Re: A good Cleaner
I have had good luck with Scotch Guard foam vinyl cleaner followed by Scotch Guard protectant
good price also
Harry
Home Cookin'
Re: A good Cleaner
when using products like Armorall, consider the slippery effect--there's a reason you don't use it on motorcycle seats; same applies to some boat seating such as benches.
c03camson
Re: A good Cleaner
Thanks for all the replies. I have tried soap and water, and a few cleaners but they haven't done much. Did some reading up on 303 so I might give that a shot.
Re: A good Cleaner
Don't ever use a product with bleach in it. It will ruin the stitching.
veritas honus
Re: A good Cleaner
I'm sure you've heard of "Awesome Orange". Dollar General has their own generic version called "Awesome". A professional detailer told me about it. It works great and it's very inexpensive. I picked up a 1qt. spray bottle of the stuff, along with a 1gal. refill for less than 5.00. It's only a cleaner/degreaser, though. It's not a protectant.
