A rant about buying a boat..My story
Status
Not open for further replies.
sankanother1
I purchased a 1986 Chaparral Villian III March 2011.Here it goes..I live in Florida Have owned many boats of all sizes.Well I came across this Chaparral on Craigslist and it was Black/grey/white..EEWWWW..I love black boats.So I call him and to my surprise the boat has been re powered with a merc mag 350 mpi with a bravo1 drive with shower and a low water pick up system with under 50 hours on it.He tells me he is a teacher at a boat school and they repowered the boat at the school.I ask about general condition and about transom stringers floor.he tells me it had been replaced already.Well that makes sense to me why on earth would any one especially MMI repower an unworthy boat.O.K. sounding really good.He also tells me that he just had the fuel tank cleaned and hasn't had any gas in it since.He didnt want it to gel..Makes sense o.k...I asked when I could see it he said the next day..I will bring it to you if you have cash..Sounded good to me HOW COULD I LOOSE?..The following day My dog died.. My friend of 12 yrs had to be put down.Sorry..O.K. So on the way home from the vet I and he showes up with the boat..I was impressed with it but ll my ambition is shot im depressed..I really dont care We hook the hose up fire the motor runs great..I question why he has a 5 gallon external tank hooked up to the motor..He reminded me he just cleaned the tank..O.K. I jump around the boat pull back carpeting stab the usual places with a pick and all is fine it was all just all the vinyl was just re done it looks GREAT! .DONE DEAL!... usually I am inviting friends and buying a lot of beer to celebrate..Nope..back in the house mopped a couple of days..The kids want to take out the boat..Ok.I installed the fuel line to the tank,loaded the boat with all the safety essentials stop at the gas station dump a hundred dollars of fuel loaded the cooler and off we went we jump in the boat Idle out of the no wake I look at every one and they are SMILING!!.I gun it BOW UP RPM"S FLYING AND.....REVlimiter... SLIP!..Do it again SLIP..Is the drive screwed?I lift the drive, hammer on the throttle water every where..No..Its blowing out..The props wrong..But thats not why I shut the down the engine..I shut it down because I smelled gas and It WAS BAD!..The fans are still running.But I opened the deck and climbed in with a flash light looking for fuel..No cracked line.Bone dry bilge.Damn..I Kept the hatch open started it up and idled back put the boat on the trailer and went home..UN SAFE!! Not playing any games..Looking back I should have not even restared it.Well the next day I Lift the cover to show a friend the boat and I see water in the bilge..O.K. Hit the pump..Water coming out..My fiend says I SMELL GAS..Me too I turned to the bilge outlet and stuck my finger in the strong stream of what I thought was water..Put it to my nose and yelled out a word I wont type here.Yup I twas gas all Hundred bucks worth dumping out on the ground my friend ran for a bucket,,I didnt care.The next day..I am in the boat with the carpet pulled out.My grinder in hand I cut the center section of floor out.To my surprise the Pine D/C grade plywood was glassed over but attached to or LAYNG on mostly Rotten stingers..It was a cover up..The stringers were black and crumbly and the crap ply wood was brand new,,I could smell the new wood it was fiberglassed And painted all pretty on top..THAT WAS THE MOMENT!.The moment I flashed back to the red plastic gas can hooked up.HE WAS FULL OF CRAP!!.No sense in calling him I would just end up more pissed and nothing good could come from it...I did much research of building stringers and fixing the boat.On youtube on line and here of coarse thank you very much FriscoJarretts. GREAT GUY!..And after crunching numbers for materials I was almost to the point of pulling the motor and drive to sell.Until I came across an person who had an add on Craigslist(I know!Thats how this all started) and the add said boat repair.It some nice before and after pics.30 yrs exp..I called Him up.He said all the right things correct materials and he came out to pick it up.. 2000 dollars later.I am now in need of a fuel tank so he can proceed .It will be between 400 and 700 bucks.Add 1000 for new prop,hoses, wire,carpet, and maybe a new bimini top.I will back to square one over a year later..the moral of my story..I dont have one..You be the judge This sucks.I can tell you this though.I will not let this keep me down.I love boats I have two classic cars projects that were put on hold because I know I would have sold my boat for cheap once I started those..I hope You guys can learn from my mistake AS MY SIG HAS ALWAYS SAID!!...It's good to learn from others peoples mistakes but I seem to beat them to it....Have a great day guys and Buyer beware.
Re: A rant about buying a boat..My story
Ayuh,.... If you'd used a few paragraphs,.... I mighta read the whole thing....
Paragraphs please . . .
So, what can we learn from this story . . .
Do not listen to what the seller tells you
For every thing that seems odd, there is a reason (i.e. the separate gas tank)
Every boat that runs at all, sounds great on the muffs in the driveway.
In a boat buying decision, when you ask yourself "how could I loose?", you will eventually find out.
What else is there . . .?
Anyway, thanks for sharing, I hope other people in the boat buying process read your story and are advised accordingly.
ziggy
imho,
ya learn that when buying a boat, generally, the seller has reason to lie. therefor you must check everything out yourself or have it surveyed.
never buy a boat w/o a sea trial.
sorry about the loss of your dear friend...
jigngrub
The usual "I bought a used fiberglass boat and the stringers are rotten and the seller lied to me" story... where have I heard that one before?
26aftcab454
it takes a long time for gas to gell--sorry for your loss .
ricohman
I couldn't read it either............
But sorry about your dog. I had to go through that a few years ago.
5150abf
I did it! I read the whole thing, man, next post please use paragraphs, my eyes hurt.
Sorry to hear about your problems, don't know that I would have dropped that much money into it though, you should have a nice boat when it is done though.
sankanother1
MY POST Header was changed to a rant about my boat..Thats not what it said.I guess iboats has started to sensor our posts.More of my rights lost in this country every day!!!!
Perfect since your a moderator......LOL!
Ayuh,.... I didn't change yer title, another Mod may have....
And,....
I'm not gonna suffer Bleeding eyes, because somebody can't type....
I myself am a single digit typist, but manage to post READABLE posts....
It's not askin' alot that posters use reasonable punctuation, 'n Paragraphs, so's yer posts are READABLE...
But Whatever,...
If a post is Unreadable, ya don't get comments....
Pretty simple,... Really.....
sankanother1
WAS IT HERE???Since March of last year??? That wasn't the point..Dont follow and turn this into a flame thread ..I posted this for other people to learn from with good intentions.Have a nice day.
sankanother1
And,....
But Whatever,...
I never accused you of changing the title..I said some one did..I was really only joking with you..Actually it was pretty funny..did you notice the LOL..I really mean that when I use it.
I should mention though that I dont think your very polite..And having the authority as Moderator I dont think you should have made the paragraph comment to begin with..it started a following..If some one sees a post and they dont want to read it thats fine.But commenting on it and putting a person down is not the correct way to handle it.
I graduated from a terrible school in Chicago......SORRY......I hope those were paragrphs
Ayuh,.... I'm tryin' to Help you get a Better experience while usin' forums in general...
Not postin' READABLE posts is Not helpin' you, nor anybody else....
I'm sorry my single digit typing comes off as gruff, but words come at a high price, so they get used sparingly...
At this point, Maybe You should go back, 'n edit yer original post, So's it's Readable....
Then you'll be helpin' Yerself, 'n anybody who might want to read it in the future....
Btw,.... Yer posts are Much Better since the 1st 1.... atleast they're Readable....
sankanother1
Are you referring to my first post five years ago?I have over one hundred and twenty posts with responses on all of them.I was actually going to just delete My no paragraph post because the title was dont trust a teacher from an marine institute..With out that is looks as if I am asking for advise which I am not.but for some reason deleting posts are not easily done.What ever.Thanks for all the help.
Ayuh,.... No problem, I'll fix it for ya,.....
Status
