Here's a note to warn about what might happen if you are not super careful:
Left wheel bearing was gravely so I pulled it apart. Well the spindle was rough so I decided to either sleeve it or smooth it with emery cloth. So I micrometered it and it was 1.725". I checked the seal and it was for a 1.688 shaft. Well!!
I found a seal for a shaft 1.719 and emeryed the spindle down nice and smooth and it came to 1.722 and I figured that was close enough. Maybe I'll work it down a bit more.
Ah, but then I checked the right spindle - *$*^@#%^!!!!! - it was 1.710-1.713". I found the nearest S-sleeve required a minimum shaft of 1.715 - Now What? Hope I can either permatex or epoxy it to that shaft and get it centered. (Not sure which to use).
That's if I leave the shaft as is and don't smooth it up. Probly should leave it rough so the 'glue' might stick better.
Don't just replace parts as per the old part numbers; measure everything; ID's, OD's, shoulder depths etc. Check existing parts numbers against specs.
If I had hired this job out what might they have done?
