A strange transom question
The transom on my Glasspar looks as though someone has cut it down to be a little lower. I only noticed this after bringing over my friends Tacoma, to see if the motor would work bettter on it. Right where the motor sits it is lower by about 4 inches than the tacoma, and there are cut marks on the sides. Was this to allow the prop to sit all the way in the water? Now I am wondering if the motor will fit on the tacoma at all. How deep in the water should the prop sit?
Mike
Re: A strange transom question
Ayuh,...
The Cav.Plate should be level with or slightly Higher than the bottom of the Boat.....
Motors come as 15", 20",+ 25".......
My WAGuess is, your motor is a 20",+ your boat Was a 25"......
So isn;t there the potential for the boar to dip down to much in the back and allow water in?
oops!
do you mean in the splash well?
