a thermostats a thermostat right??
markle
aq151 motor thermostat 33 euro
volvo 740 thermostat < 5 euro
to my mind they do the same job, my question is ... is this another case of adding the word Penta and bumping the price!
As cash rich as I am I do not want to waste the 5 euro on a car thermostat if it doesn't work :)
Re: a thermostats a thermostat right??
Ayuh,.... T-stats are 'bout Temperature, Not euros...
If it's the Right Temperature, 'n fits the housin', is what counts....
Two completely different types of engines (and thermostats), the 151 is a Volvo 4 cylinder, the 740 is a GM 7.4L engne.
They may both be thermostats, but a Volkswagen and a Ferrari are also both cars.
markle
Volvo 740 (its a 530 head on a red block) this may well be another Europe Usa language divide like the plus gas incident :)
The stat is the right temp but the car runs in to a rubber hose not an elbow, but that said they do look the same which is probably where I start to go wrong!
Gonna go with your initial advice
"If it's the Right Temperature, 'n fits the housin', is what counts.... "
and buy the car stat, and if only we had 7.4 motors here in the Uk with petrol (or gas) costing around ?1.35 or $2.11 per litre car engines tend to be smaller :)
My largest was a 4.6 v8 and people thought I was nuts (they were right but it was a big old motor).
Mark
Nickypoo
$8 a gallon! Wow!
I put a standard thermostat in my motor (Volvo 2.1L). If it's closed cooling I don't see why it would make a difference as long as it's the right temperature.
markle
That's probably why we pay by the litre :)
quintonwatts
For my penny's worth (proper currency) get the right thermostat and have peace of mind. Put in a speciulative substitute and when you have temperature problems you will question whether the thermostat is wrong or something else. If a job is worth doing it is worth doing properly.
