About to undertake first fiberglass project, need help!
stephentyler20
Sorry for posting on this yet AGAIN, but I'm still feeling quite uneasy about how to approach the fiberglass portion of this project. I have ZERO experience with fiberglass.
My idea is as follows: I'm going to smooth out my console (pic below in its current state) with some puddy to fill the cracks around the plywood. Then, after saran wrapping the plywood bits, I'm going to apply mold release wax to the whole shebang. Then, layup 6-10oz of fiberglass mat, with the idea being to create a cap of sorts that will house my gauges, buttons, etc. Once the resin has cured, I will sand, fill, fair, and paint the fiberglass to get a smooth finish, remove it from the helm, remove all the plywood, and affix the new part via screws or hinges.
I have several concerns...
- what TYPE of polyester resin to use? I assume laminating at first, but then do I need to use a wax-resin or something?
- is mat ONLY OK? Should I be able to smooth that down with enough sanding/fairing?
- how about 'glassing the vertical surface? Will that be easy to do, or will I need some sort of filler? If so, what kind?
- Any other tips? Suggestions?
I'm really, really green here... I don't have any materials or supplies, so I'm trying to make as few trips to the shipstore as possible. I don't have a good fiberglass supply store, just marinas and such.
Thanks for your help!
Re: About to undertake first fiberglass project, need help!
So you want to make a copy of the console that you can then attach with screws or hinges????
If you want to go with straight fiberglass you will be spending allot of money and may not obtain the results you want.
Plywood can really be your friend and molded in for support.
A dash like that should really be vac-bagged for the best results.....
Other's will chime in.
stephentyler20
That's essentially right... Cost doesn't look too bad, really. Estimated about $120 for materials.
stephentyler20
Also would it be better to use cloth instead of mat to get a smoother surface? Or mat, then cloth? Argh, so confused!
