Add a gear lube monitor?
Juel-dk
Hi All
Is it posible to add a gearlube monitor on a Alpha One Gen II??
I know some of them are born with it..
But can you fit one that hasent been born with it?
Kind regards
Morten Juel
Denmark
Re: Add a gear lube monitor?
Ayuh,....
It's probably already plumbed into the back of the boat, at the inner transom plate Now.....
Juel-dk
I havent seen it anywhere, but ill take of the drive for service the day after tomorrow, so ill look again, do all gen II drives have a monitor?
Haut Medoc
I don't think the older ones did, but you should be able to fit one....:)
91, 92, and the early 93 Alpha I Gen II drives didn't have them, nor a way to install one like in use with the newer ones. No place for the check valves in the bellhousing, the drive, or the fitting thru the transom shield.
Those drives do have a dipstick in the top of the outdrive cap.
Juel-dk
Hi :) Thanks for the info, mine is a 1993..
Ok, so i will forget about it then :)
Kind regards
Morten Juel
Denmark
qystan
Mercury has a kit P/N 69622A7 for the Alpha Gen I. Will work with any drive. Got it on my drive.
Comes with a reservior, hoses and fittings.
1. Reservior mounts inside boat,
2. drill through hole in transom for hose at about 2-3 inches above and left of top of transom assembly.
3. Remove drive oil fill vent plug
4. Connect hose (half ss braided/half rubber) to reservior and drive vent hole.
Kit comes with cover and grommet to cover amd seal transom hole.
The self filling/replenishment is no big deal. As a leak indicator - nothing comes close - worth every cent.
45Auto
Doesn't seem like it would be too hard to add some kind of float-based level sensor to the cap of the resorvoir on the kit QYSTAN described above. Heck, my cheapo cars have them on the windshield washer fluid! I'm sure it would be entirely too much to hope for that one of those would simply screw on though!
billbayliner
Here is the kit.... Going for around $170
