Added a Tell Tale to my Motor
David Young
I've been wanting to add a tell tale to my old 1977 70hp Evinrude. With several days of nice warm weather I figured I would do it. I did it using this Forum instructions. It was easy to do but it was hard (mentally) to drill a hole in the top of the motor. Everything went smooth except I had to replace the plastic elbow fitting with a straight brass fitting from my local hardware store because of not having enough clearance to screw the elbow fitting into the hole. I haven't been able to try it out yet because my motor is still winterized and we will be having more cold weather coming. This is what I went by http://forums.iboats.com/
jbcurt00
David, link goes to forum homepage, not a telltale topic.
