Added Marker Lights and Now I'm blowing fuses
Hermyboy3000
My rear trailer lights worked fine (stop, turn, running), except that I had no marker lights.
So, today I added new LED marker lights. The install was pretty straight forward, the new marker grounds to the trailer and the hot lead taps into the brown wire. But, when I turn the running lights on - POP - I blow the 10a fuse. What's the deal? Is it a bad ground? Why did my lights work before, but won't with the new markers?
One last note, my trailer lights and wires are only 4 years old.
Thanks!
Re: Added Marker Lights and Now I'm blowing fuses
So..if you disconnect the one new marker light it doesn't blow the fuse?
Ayuh,... You screwed up Somewhere,... You have a Dead Short...
Splat
Yea something happened.
Places I would start checking are:
Make sure the new LED light is wired correctly with the positive and negative.
Also I would look very closely around the area where the positive wire comes through the frame and make sure its not chafed.
If you don't find the problem there now its time to start doing some investigating. You'll have to trace the entire brown wire from the plug all the way to the back of the trailer and make sure its not chaffed somewhere.
Bill
Miroash
Banned
What is the total draw of all your lights? I believe LED lights draw less amps than regular bulbs so you should be ok with 10a fuse. I think you must have created a short with your attaching hardware.
can-amsledder
Bill
What are the two colors of wires used on the new lights you bought? Red and black or maybe white and black? If it?s white and black white will be ground. Don?t ask me how I know this!
Doesn't matter if you wire the LED lights backwards as far as drawing too much current. If you wire them backwards, they just won't turn on at all.
captharv
Correct!
Either you pinched a wire, a connection is grounding to teh trailer, the new light fixture is defective, or you have just plain exceeded the fuses current rating with too may lights.
try disconnecting the new lights. If the fuse don't blow, then add one at a time. When the fuse blows, disconnect the last one added, and connect it ITSELF to a power source. Fuse blows if the fixture is defective.
