Adding a Tilt sw on the transom
wire knot
All the outboards i've had have a tilt switch in the cowling.
Anyone ever added one maby through the transom of an outdrive.
I have to tilt up to back into the garage, tilted up. Then have to tilt down to finish backing in.
A rorlal pian to get in the boat to tilt. Also for draining at the ramp
Any reason this would be a bad Idea.
All comments welcome.
WK
Re: Adding a Tilt sw on the transom
Ayuh,... All it takes is a toggle switch, 'n a few feet of wire....
Just wire it parallel to the existing circuit....
wire knot
Yep Bondo,
Been Wiring.....STUFF...... since 1980.
Kinda looking for any negatives on this Idea.
Thanks
WK
christoner2002
If you have a MerCruiser drive, there is a one you can by from them, that plugs right in. I bought on this summer for mine. There was 2 different ones, one for a round plug in style, and that was what I had. The wiring harness is very nice, and it is a sealed plug where it plugs into the Hydraulic pump.
wire knot
Very Nice,
Mine is a Volvo.
WK
