Adding a water separator?
Ron-O
I'd like to add a water separator this year to the boat. Trying to find a good mounting point with the 4.3 Mercruiser I/O. So far the only place that looks decent is under the front of the motor in the bilge. Is this a bad idea? Can it be higher than the fuel pump??
Ron
1991 Cheetah 2000LS 4.3 Merc Alpha 1
Re: Adding a water separator?
Ayuh,... Sure,... Closer is Better, but not mandatory...
Put where it can be got to, to change as Easily as possible...
