Adding an outboard bracket/offshore bracket
The John
Hey everyone,
Having now used my boat over the year, I am thinking about adding an outboard bracket/offshore bracket (east/west coast thing i think). I am looking to add a better way to come out of the water other than using my plastic ladder and I would love to have the extra deck space. I may have a line on one to install in my Mariner and I have until March to get it done before spring chinook season starts.
I searched around but wasn't able to find any specific information around installing an offshore bracket onto a riveted StarCraft.
Does anyone have any experience/advice/hatred they could share especially around bracing the transom area for this addition?
Here is my plan for installation (assuming it all comes together perfectly):
1. Add a sheet of aluminum to the transom (1/4 or larger thickness).
2. Connect the stringers to the transom
3. Use SS 1/2in hardware and large diameter washers to mate bracket to transom
What am I missing, what would I need to add for additional strength?
Thanks Everyone!
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
I am in no way qualified to give advice on an outboard bracket, but it has crossed my mind for my boat as well! I like the idea quite a bit for better handling, a step/platform, and more space in the interior. Go for it so I can see how you do it!!
If it were me, not sure if I would weld or rivet the bracket on. But I would absolutely reinforce the #%^* out of it, tying it into the stringers, floor, and walls. Basically everything I could to distribute as much force as possible to the rest of the boat.
@BOYS & TOYS I would guess you may have some expertise in this kind of fabrication.
Hey everyone,
Thanks Everyone!
Are you looking at flotation pods or an outboard bracket?
Big difference in design and purpose
The John
Thats what I was thinking as well (tie everything together). My buddy is a structural engineer, he is going to think on it and provide some input. I think I will bolt it on as I think that will be a better method to tie everything together.
The John
I am thinking it will be a floatation bracket, this way I can add an easy way to get in/out of the boat via water and it will add some space to the dance floor.
I am planning on getting rid of the splashwell, but keeping a 3/4 wall to keep water out and provide a space for storage of gear and fish. similar to the below pic (stolen from the net).
sidingguy
I had a 19' Starcraft Islander V5 hull with a Sea Drive unit on it. 1986 year model.Rebuilt the boat,new transom floor etc. No knee brace or any other bracing present.Was really surprised by this.Motor was a 1.6 liter OMC which if I remember was 110 hp 2 stroke
