adding voltage regulator
renoduckman
I know this topic has been cover a bunch. But i have an 80hp 1988 Merc with the clasic over charging issue. I cant prove it but i think i burned up a depth finder.
So can you recomend a voltage regulator that i can add to this? I do electrical work so i figure i can do it with some info and advice on which one to buY? thanks Joe
Faztbullet
Re: adding voltage regulator
Just order part #815279A2 from Merc as its a complete kit.
renoduckman
Thanks men, both of these look like the solution. I also found that sierra makes one. Next time im fishing im going to take my fluke and recheck the voltage. Then i will go and get one of these. Thanks Joe
CDI Tech Support
CDI Electronics parts are made in the U.S., most carry a 2-year warranty & are backed up by the best certified Tech Support in the industry. Our certified Tech Support is free to anyone if you buy our product. Manufacturers "S" & "M" do not offer certified tech support & their parts are made in Germany & Mexico.
And none of the other guys offer comprehensive troubleshooting guides, through 28+ years of research, like we do.
As for your overcharging issue, check our guide on this:
Battery Charging Issues, Regulator-Rectifiers and Tachometers
Most charging issues & regulator/rectifier failures are a result of improper battery type and/or battery charging neglect. That guide will detail what type battery is recommended for outboards & why.
If your engine only has a 3-post rectifier, that means the battery is having to act as its own regulator, which places further strain on the battery. Definitely replace it with a combination regulator/rectifier. Our part# is 194-5279 List price is $158.00. We sell direct or you can purchase through iboats.
renoduckman
Thanks, very helpfull and interesting. I have some understanding of this. I bought good old Merc that sat for long time. I bought dva adapter and flywheel removal tool. First the swithcbox was bad. Replaced it and it was ok.Then a phantom problem. All tests showed ok but it still acted up. Finally removed flywheel and found bad insulation and corrision on wire of the trigger, right where it attached to the trigger. Replaced that and the stator just for the fact that i was allready under the flywheel. Motor has been running like a rocket for a couple of years now. And when i first got involved the rectifer had a bad diode and i replaced that too! But i just put in the standard merc one at the time. Hind sight is perfect.
I will recheck and test this weekend if i make it out. And you dont have to sell me on CDI. I was very happy with the switch box i bought. And i think the stator is from them too but not sure?
Thanks for all the help. Joe
