advice for new boat owners
justarobb
I wish someone told me........NEVER LAUNCH YOUR BOAT WITH THE TRAILER LIGHTS STILL PLUGGED IN. Major damage to the trucks electrical system!!
Uraijit
Banned
Re: advice for new boat owners
I've never had a problem with it... Is it because of salt water?
david_r
the only prob ive had is popping a bulb when waqter hits.
how deep do you put your trailer in the water?
i never even sink the exhaust and i have boom tubes.....although occasionally one of my buddies will sink light and put the exhaust in the water.
are your lights low or is your hitch low?
triumphrick
You must have other wiring problems, or something really strange about your tow vehicle. I have been dropping boats in salt water since the 70's, and never fried my vehicles wiring or electrics.
642mx
I never unplug mine... no problems yet. :D
Navy Jr.
I don't unplug either. Have 2008 Shorelandr' with LEDs. Dealer said unplugging is no longer necessary on trailers equipped this way.
Just wondering... what sort of damage was done to the truck's electrical system?
JustJason
the voltage is so low (relatively) that water (salt or not) shouldn't cause a short across 2 poles.
Unless you were dumb enough to back your truck in till the water was coming in through the doors, and your ecu is mounted low in the cab.
109jb
The reason for unplugging the lights isn't for anything electrical at all. It is because when cold water hits the hot glass of the bulb, the glass pops. Won't happen if the light housings are sealed. I have sealed non-LED lights on 3 boat trailers and never unplug them when I back in. Never had a problem unless a housing is broken. The absolute most anything having to do with your trailer should do to your tow vehicle electrical is blow a fuse.
Monkey Boy
I had blown a couple of bulbs this way, but never electrical damage. I've replaced the lights with submersibles recently and haven't had any problems with leaving them plugged in.
mike64
I forgot to unplug my trailer once, figured I'd be replacing the bulbs at least, but I was fine.
ilmostro99
Lights? Look at all you fancy-pants city folk, with Lights on your trailer. It's been my experience that the reflection off all the beer cans flying around in the back is more than enough :D
Seriously though, I've never unplugged either and have never had a problem. I've sunk it pretty deep on occasion too.
Erik
I have disc brakes with a backing solenoid so I couldn?t unplug my lights if I wanted to. I have yet to pop a light bulb let alone blow a fuse.
Unless the trailer was wired incorrectly into the truck the worst that could have happened was that you blew a fuse.
KeyWestBoater
When I had my hitch and harness put on they told me to unplug before backing in. I have a new trailer (2008). I forgot once and popped the adapter module that's part of the hitch harness. Cost me about $25 and 30 minutes. The module's part of the harness so I had to replace the harness. Older cars/trucks dont use the module so maybe that's why some don't have the problem. My trailer tongue doesn't touch the water. I have a 2003 Highlander.
Thanks,
KWB
j_martin
I bury mine deep and leave the lights on. It's the only way I can hit the trailer at night. If the lights and wiring is good, no problem. If bulbs blow or blink, it's time for some maintainance.
Thanks,
KWB
The aftermarket modules/ harness are junk. They splice into turn and brake signal harness at the back of the truck then use a "module" to fool the trucks computor into thinking there isn't an overvoltage problem in the lighting circuit.
I've never had an issue with a factory tow harness
reelfishin
Unless something was wired way wrong, I can't imagine it doing more damage than blowing a fuse. Most trucks these days have specific trailer tow circuits as well that isolate the trailer lights from the rest of the trucks wiring system and lights.
On some vehicles with factory light modules, it's wise to wire trailer lights in with a relay or converter module if you have amber rear turn signals.
I rarely unplug any of my trailers, mostly since I just plain forget and have never had any problem other than the occasion popped bulb from the hot bulb hitting the cold water. Never a short, never a blown fuse. One some newer trailers with surge brakes, there's a reverse solenoid that must be hooked up to allow backing.
Who is telling you there's major damage? What type of damage? How was the trailer and truck wired? What type of truck?
KeyWestBoater
If it becomes a major issue then maybe I'll look into a factory harness. Meanwhile I've only had one problem so as long as I remember to unplug then I'm ok. Almost forgot another time but my wife reminded me! :redface:
KWB
