Affordable Diesel Power - is there such a thing?
HighLineCBR
I was just looking at some Diesel engine options. Not that i need to repower but was just wondering whats out there.
a new Mercruiser MPI motor with about 320HP will cost about $10,000 installed. A comparable Cummins Mercruiser diesel motor will cost about $30,000 installed.
This doesnt seem a feasible option for us "regular" boaters to consider. I would love to have a diesel motor... more fuel efficient, more power, and will run forever. But at $20K more ??? I probably wouldnt even burn through $20K of gas in the life of the boat.
so... is there an affordable Diesel alternative for the "regular" boater? new or used?
Re: Affordable Diesel Power - is there such a thing?
Nope,.... Not really....
Howard Sterndrive
1HP from a gas engine = 1HP from a diesel
nothing runs forever.
Now that diesels are loaded down with electronics and turbos and such, I don't know that they're much more reliable than a gas engine in general. The computer makes 'em go now.
Heavy duty diesels with wet liners and pump and line fuel systems are not found in recreational boats anymore... you're getting parent bore blocks, or maybe dry sleeves, and common rail unit injector fuel systems prone to high tech issues that only certain marinas have the training or tools for.
Howard Sterndrive
Preliminary list pricing for a TDI 225-6:
1. Without gear = $24,470.00
2. With Bravo 1 Mercrusier Sterndrive = $29,677.00
3. With Bravo 3 Mercruiser Sterndrive = $30,260.00
that was a few years ago.
I think VW did about what Toyota or Yamaha did in the rec. boat inboard biz in N.A.... disappeared
Ring Power no longer has any VW reference on their site
Is VW still around with the marine TDI?
Autotech1
Is there a Merc bellhousing for non-computer 12 Cummins?
