Aftermarket manifolds/risers?
JaCrispy
What's the deal with GLM? Is it just the crappy gaskets that come with them?
No it is the crappy casting.
Your smart money is with OEM or Barr or Osco.
HT32BSX115
If you have access to a milling machine, you can "clean" them up but if you have to pay someone to do it, it might be cheaper to just get BARR, OSCO, or OEM......
Ayuh,.... On mine, I hada machine .020" off the tops so's the gasket Surfaces were flat enough to hold a gasket,...
The inner gasket surface was .020" Below the outer gasket surfaces,....
rick3452
Barr is a good product USA made, just buy the OEM Gaskets.....
