Airguide tach not sitting at ZERO ?
MassillonBuckeye
Tach sits between 200-300 RPM when off and even when disconnected. Is there any way to adjust this? Where the needle rests. Have had the boat for a couple months, and didn't notice this until a few weeks ago.
Re: Airguide tach not sitting at ZERO ?
Ayuh,.... Does it read correctly when runnin',..??
If so, What was the problem,..??
MassillonBuckeye
I don't think so. I think its reading 2-300 higher. I don't have a means to test 100%, but I highly doubt I'm idling that high. I am idling HIGH, but not that high.
The problem is I'm wanting to adjust my idle speed screw because its idling a bit high. I guess I can just subtract the 200 RPMs or so. Thought maybe I could zero it out somehow though.
