alarm single beep sometimes.
shanel
aug 2007 is stamped on the 4.3 tks,it gives a single beep every now and then.all fluids are full except the outdrive resivoir and it's about a half inch from the full mark but about a inch above the add mark.I know you guys want the model # and or serial #'s but i was hoping this was enough info on this particular engine since i don't have the other numbers available right now.Oh yeah the temp stays just above 160 after she's warm and stays there.
Re: alarm single beep sometimes.
Ayuh,... Welcome Aboard,.... Look for corrosion at the sensors...
