strombolichef
- Joined
- Aug 28, 2007
- Messages
- 95
So I had my chaparral boat with a Volvo Penta 4.3 gxi the sitting for a couple of months and then when I went to start it up the alarm sound that turns on when you turn the key and it's supposed to turn off when the engine starts would not turn off. All gauges work and we're reading normal levels so I understand it might be a sensor I found the oil pressure sending sensor the one with the single knife blade attachment and it crumbled in my hands but once it was disconnected the alarm did not shut off nor did it shut off when I disconnected the two manifold temperature sensors or that other oil sensor that's near the one I just mentioned. I welcome any advice you can give about how to solve this problem so I can use the boat again PS I'm repairing that oil sensor that broke off thank you.
