Alpha 1 gen 2 bellows service
MBAKER
What is recommended service interval for this? Safe to assume it would be longer For a boat trailered and stored inside year round? When these do fail is it a slow leak where you start to notice water and bilge running or is it going straight down if not caught.
JustJason
There is nothing in print other than "inspect yearly".
The rule of thumb is that if they are OEM bellows and not aftermarket, 5 years is the expected life span.
When they fail, it will start as a slow leak that will get exponentially worse as the tears grow in size.
X2 I inspect yearly. My 2004 boat the OEM ones lasted 18 years and still were not leaking- fresh water lift kept boat.
Given that lifespan of the OEM parts doesnt make sense to use aftermarket unless you are selling it
Lou C
I tilt it up and use a bright flashlight to check for cracks in the folds, as soon as you see that, the rubber has gotten oxidized and hard and is now due for replacement. I get at least 10 years out of OEM Cobra bellows.
Lou C
The bellows should definitely last longer if the drive is stored down. I'd use OEM for the bellows for sure, and for impellers as well.
drewm3i
In my experience, the OEM ones last for at least 15-20 years if stored properly. My 30 year old boat is on its second set that were replaced in 2018.
Due to where I use and store my boat the drive is 3/4 to all the way up almost all the time and I got 18 years out of them…
Lou C
It’s good to know that because for some that’s the only option.
yep I'm in that group. Have a holist but its in 25-27" of water. I leave the boat on a trailer, when I used to leave it in an old barn you parked it outside and the owner moved them in at his convenience. For $12/month storage who cares... My father built a 3 bay garage where it winters now but he may need to pull it out for one reason or another and I take the battery out so its full up all winter.
Bt Doctur
when you decide to replace the bellows CUT the oil line before removing the hinge pins and remove the hoses using a razor knife gently on the transom side
You DO NOT want to break the plastic fitting for the oil fitting on the transom side.
drewm3i
I have done that once lol! I was able to replace it without removing the engine but it was a *****! I was like 21 or 22 at the time and was made of rubber.
MBAKER
Last service was somewhere around 2010 so going on 15 years now. I looked last week and although the drive bellows doesn’t look bad I can start to see cracking in the folds. Cooling water hose looks worse and shift linkage isn’t far behind. Been trailered and stored inside all of those 15 years. Not sure what previous owner did.
