Alpha 1 Outdrive install. Keep damaging o-ring
mudweiser
1989 Alpha 1. I just finished installing new bellows. They looked good, but i put them on anyways being i had to order them.
Every time i remove the outdrive, the large O-ring between the outdrive and the inner housing is bad. Whats the correct way to install this large O-ring? The last one i removed, the bottom of the o-ring was crushed. Prior to that one, i installed the o-ring in the housing first. The last one i put the o-ring on the end of the outdrive then installed the outdrive. Can anyone relate to this problem and tell me what i'm doing wrong?
Re: Alpha 1 Outdrive install. Keep damaging o-ring
Ayuh,... Most guys glue that oring inplace with bellows cement,...
I slather the Grease to it to hold it in it's pocket in the housing...
