Alpha 1- Upper Drive Gear Bearings
qystan
Got the set of new bearings for the uper drive gears. It comes with the large and small spacers. I suppose this answers my question of throwing the spacers.<br /><br />Problem is the bearings don't look right.<br /><br />I got the 31-35988A 9 bearing set. It says 1.50 Heavy Duty ratio only. I have 1.50, are there two different 1.50 gears? The set consists of 2 different bearing part numbers. <br />1. One bearing is Timken P/N 386A, 382A, the other Timken 375, 371A. The numbers are the rollers and cups. <br />2. Main difference is the ID, the 386A is 1 7/8", the 375 is 2". The shaft end on the drive gear is straight, not stepped as shown in Merc parts illustration. The old bearings are both 386A's.<br />3. The new spacers are also thinner than the old, about half.<br /><br />Did I get the right bearing set? Should it be the 31-35988A12 instead?<br /><br /> :confused:
Bt Doctur
Re: Alpha 1- Upper Drive Gear Bearings
definitely you got the wrong set.If the gear is straight and not stepped down you need the 386/382 setup.
qystan
Any idea what is the the correct part number for the gear set?<br /><br />The parts calalog shows 3 bearing sets. It specifies the 1.50, are there are older 1.50's that use the A12 and not A9 bearing set?<br /><br />
<br /><br /><br />Thanks.
Bt Doctur
need the type of drive,year and serial number
qystan
Its an Alpha Gen 1. Serial number 0D485637. <br /><br />I got this as a used boat, no info whether the gears have ever been changed. <br /><br />Thanks again.
Bt Doctur
that ser # says 1977 898/228 says gear set is <br />18410A2 1.50
qystan
I am sorry Bt Doc. <br /><br />Typed gear set instead of bearing set p/n.<br /><br />The drive is a Gen 1 with 1.50 gears, the teeth are 22 and 20 on the driven gear.<br /><br />Here's the parts catalog, can't get it to show in the previous post.<br /><br />
<br /><br />Item 21 lists the bearing part numbers.
