Alpha 1
realoldsalt
Anybody know how to remove the three boots on the Alpha 1 Gen II Outdrive without removing the engine ,and the tramson plate. I have two of them that are thirdteen years old and leaking.:)
Bt Doctur
Re: Alpha 1
There is no need to remove the engine to change the boots.
go to the adults section and download the manual for the drive.
Re: Alpha 1
Ayuh,... That's All done from/ at the Outside of the boat...
jtybt
Re: Alpha 1
Gotta remove the drive. cut the old bellows off for easier access.
There are access holes for a long thin screwdriver to remove the hose clamps. I drill them larger to fit 1/4" drive 5/16" socket and extension. makes it a lot easier. I even drill new holes to position the hose clamps at a better angle.
Get the tube instead of the bellows for the exhaust.
realoldsalt
Re: Alpha 1
Thanks alot, when the rain stops coming down in buckets today I'll see if I can remove the old ones.
