Alpha drive play in prop shaft
JackBronson
Hello,
2008 Mercruiser Alpha drive. The propeller shaft has about 3/32" (its more than a 1/16th, less than an 1/8th inch) play in and out. the prop is tight on the shaft. the whole shaft is moving in and out.
You can check the video below.
YouTube video with drive shaft play
Is this play normal, or in an acceptable range?
Thanks.
karayj
I would take the prop out and reseat it . Has it been removed and reinstalled recently ?
muc
That's a little less play then normal. Your fine.
Ayuh,..... In- out play is completely normal,......
isaacs
Mine does the same thing. I showed it to the mechanic at the dealer where I bought it and he said not to worry about it. I appreciated his honesty, not trying to get me to spend money on it.
