Alpha Gen I& II bell housing interchange
bounder4465
I bought (cheap) a 92 bowrider with a 4.3, and an Alpha I Gen II outdrive. The little noise in the u-joints was a broken u-joint assembly that busted the bellhousing and damaged the transom/gimble assembly bracket. I have no place to mount a new boot. The flange is gone on the bell housing, and chipped away in several places on the gimble transom housing. Can I use any alpha bell housing and transom plate, or will it need to be the gen II?
Re: Alpha Gen I& II bell housing interchange
It's Got to be a Gen II...........<br /><br />Sorry......<br /><br />Try ebay......
bounder4465
Thanks for the info. I bought the boat on ebay for $1501.28 !!! I had to replace the electric fuel pump (a new one on ebay was $97 including shipping), so I dont have much in it to date. The engine has 170lbs on all 6 cyls, and it runs perfect, so I will return to ebay and the hunt is on for some parts!
bomar76
Sounds like you will come out ok on that deal!
If it'll help any in your search, you need Mercruiser part number 806031A 2 for the bellhousing.
