Alpha gen1. How much prop spin in Neutral at higher engine rpms?
Mariah180
Wondering what's typical / normal?
My 2001 4.3l alpha gen1 when in neutral and at 1500-2200rpms the prop will spin.. This is out of water with rabbit ears on. Unknown if in water with water resistance if the prop would move.
Re: Alpha gen1. How much prop spin in Neutral at higher engine rpms?
Ayuh,... That's just the drag of the oil against the gears,...
Perfectly normal...
