Alpha OD
sethjon
94 OD won't go up unless you tap on it. Loose connection? Solenoid? Any ideas?
Re: Alpha OD
Tap on what, the drive?
sethjon
Re: Alpha OD
Hey Don: I am actually asking for a friend. He used the boat this weekend and only told me he was tapping on it. I thought the drive but then thought it must be the motor that puts it up and down and he thought it might be the brushes in the motor. My thought is either the connector or a solenoid. What do you think?
Also, thanks for the quick response.
Bt Doctur
Re: Alpha OD
go with all three
brushes, loose connection, corrosion
Re: Alpha OD
Ayuh,.... More than Likely corroded connections...
A testlight will tell ya where the Problem is...
