Alpha One Alternator/Battery Cable Issue
OneFoot81
Hello- The wire that charges the battery from the alternator (orange in my case) had the ring break off at the alternator. There really isnt much slack as the wires/harness is pretty tought and electrical taped/harnessed together around the engine. Also the alternator post is a bit dethreaded/weathered, but i brushed it and I think it should be fine for now.
Since there is not much slack, cant just put on new ring. Can I run a new wire and sister it to the other wires with etape so i dont have to deal with rewrapping the harness....or do i really need to undo it all and rewrap it around the engine?
Obviously a noob, thanks for any help
Mercruiser alpha one 1994
Thanks
B
Bt Doctur
Re: Alpha One Alternator/Battery Cable Issue
a 10Ga. extention wire crimped properly will work.Or an Electrician twist and solder
OneFoot81
I will go the crimping route
I was thinking it would be better not to extend it....but ill give it a wirl.
Thanks
I would replace the wire if it were me. It should also be an 8 ga. wire, not 10.
