Alpha one drive gear questions
MCL
Hi
Im currently rebuilding my alpha drive due to a oil leak to the bellows area.I have the mercruiser manual for the drive and understand the two different bearing type methods.I think I have it right but would like to have it confirmed,so all alpha one gurus please chime in.
Im fairly sure the bearing assembly is the older type with the shim spacer,which means you dont set the rolling torgue,you just torgue the nut to the specified torque.
This is due to following reasons:
-The nut on the gear end was ridiculously tight,I could not break it loose by hand but had to use and impact wrench.If it would be the newer style bearings without the shim where you adjust the preload with the nut it would not be on this tight(held by nyloc and loctite).
-The bearings move freely of the drive gear,the inner races just slide on.I can completely diassemble the inner and outer races and remove them from the drive gear,krrping everything in order ofcourse
-There is a spacer between the inner races.It was just alot bigger than I thought reading the manual.
So this is the older type bearing correct?This means that I only torque the nut to 95nm.
The leak was due to a bad oil seal and grooved seal surface on the yoke.I cleaned the surface up with ultra fine scotchbrite and set the new seal 0,5mm deeper so that it will ride on a new surface.I suspect there has been a bellows leak at some point because there is rust on the seal surface and u-joints,this is probably also what caused the groove on the surface.The u-joints seem ok due to generous greasing.
Btw.The water pocket cover had melted,I was unsure if it was leaking so I thought I replace it against all the advise on message boards to do so.I gently heated up the housing and the sprayed cooling spray on the hex ends of the screws.Generously applying wd40 and blowing the hex ends with a extension and a hammer.I repeated this a few times before even attempting to unscrew the bolts.I dont know which of the procedures above made the most difference but I was able to unscrew the 4 screws with ease without making any damage to the aluminium threads in the housing.This outdrive has been used in saltwater for 26 years and here the boats stay in the water for 7 months,so the screws should have been properly seized in the housing.
If anyone has to remove the water pocket cover I would suggest trying the method above.Stainless steel and aluminum vary greatly in different thermal expansion,heating and cooling + the shocks from the hammer helps to break the two materials apart.
the nut was held on by loctite. you need to heat the nut with a torch to release the loctite.
Rick Stephens
Nice going on the water pocket bolts. I broke one of those off once. Was able to drill it out, but that was pure luck the drill stayed centered.
achris
More fish than mountain goat
You definitely sound like you know where your towel is. Very nice work on the wpc. I've done quite a few of them. Rare to not break a bolt. And yes thermal and mechanical shocking definitely helps. So does praying to whatever deity you follow. :D
Same with the yoke seal. That's the same as I do, set the seal 20 thou deeper. :thumb:
Chris......
MCL
Drilling stainless is a ***** alone,but to do it in an aluminium housing is just madness.Nothing you do with a hand drill.
2 thousands of an inch would probably be enough,I just dont have a press and correct tools to set the seal correctly so I just put it somewhat deeper.Turned out to 0,5mm.
I put it together last night.Since this is the old style bearing with spacer you only torque the nut down to specified torque.Did that and the bearings were solid,no movement at all,loosened the nut and retorgued it and the bearings spin like they did before.Go figure.I had marked the nut and shaft,torgued the nut to specified torgue and the nut is maybe 1/16 of a turn from being in the same position before i dismantled the drive gear.
