Alpha One Gen 2 Issue
atomb
So I was hoping i could get some feedback..
Got the boat going and im having what i feel to be slop moving from through my gears Forward N Reverse
So the boat will engage in all gears but lest say i put her in reverse :the throttle will be engaged as well and a little too much if you know what i mean..
Illl kick it in reverse and ..Im moving way quickly off the bat ..this is dangerous .. Im assuming a cable adjustment of sorts .....
Any ideas as to helping with this would be greatly appreciated.
Thanks for input
adam
Re: Alpha One Gen 2 Issue
Thanks for input
adam
Ayuh,.... Are ya sayin' it won't Idle in reverse,..??
atomb
Yup but you sure said it better than i did. :)
So with that outa that way...... What should i be adjusting?
Btw thanks for responding Bondo its been awhile since i have been on the site and i see your still a major contributor.
Im sure i owe you few beers and then some.
adam
