Alpha One Gen 2 seal question
delta1
I made a mistake and did not notice where the 3 1/2 inch x 3/8 inch x 1/8 inch (approx size) seal went when I removed the drive a few days ago. Do I install it on the upper drive where the gear end yoke is? Does it get glued on?
Thanks,
Paul
Re: Alpha One Gen 2 seal question
I would guess that you are referring to (a) the rubber gasket. Glue it into the bellhousing with some bellows adhesive (as shown), if it gets bumped or moved out of the way and cut when installing the drive and you don't notice. Consider the price of a gimbal bearing, ujoints, and possibly more as he outcome of that seal going bad.
delta1
As always, Thank you.
Paul
oscar1968j
Hello ! every one i have 1990 campion in/c .... i/o eng / drive ?? alpha one
4.3 mercruiser with alpha one 1.84 rati
and i have trye to get it running i purchase this boat from family and when i take the boat to the service i was been told that the engine was sea's up and they trye to turn the engine by hand will not do it and it will take abouth $3000.0 to get it runing and it will cost me more for the outdrive
that was in CA Ventura county the shop is sitting near the hyw 101 so i ask the service people to put my outdrive on the boat thank but not thank you
so i take the boat home them couple years later i was playing with the boat and trye to turn the eng. by hand and the eng. turns fine so i desited to put together by my self do i have to replace any gaskets on the outdrive / or the housing / need some help
please
thank you
Ayuh,...
Oscar,....
Welcome Aboard,...
If you want Answers,...
You need to post a thread of your Own,....
Not Hy-jacking this thread about Somebodyelse's issue, that's Different than Your's.....
The Thread Starter Button is at the top portside of the screen, at the main I/O forum page.....
