alpha one gen one flush port
yonu
hey all i need some advise on a idea i am having i have a alpha one gen one connected to a 351w i know that i can add a flush port to the engine itself to flush the engine however since the seapump is in the alpha one i am confused on how to deal with not burning out the seapump
thanks,
yonu
Bt Doctur
Re: alpha one gen one flush port
is this in the water or out of the water
yonu
sorry forgot that part is out of water
Bt Doctur
all you do is hook the muffs to the lower unit and flush away
yonu
i know about the muffs I just really hate having a lake aroundthe boat will working on the motor just from around the muffs was trying to get out of using them.
you are going to have water coming out the exhaust anyways
besides, if the pump is working properly you will have little to no "spillage" out the muffs, but you WILL get water out the back of the boat anyways due to the exhaust
yonu
well I will try a different set of muffs (as they are atleast 20yrs old) then as I just did a full rebuild on the sea pump and I get a steady flow around them even with the engine running.
Ayuh,.... That's pretty normal at idle,.... Ya Want excess water...
Is it passin' exhaust water too,..??
yonu
OK sorry to ask but what do you mean by passing exhausted water
Ayuh,.... Expelled water, from the idle relief ports on the transom.... Proof, water is goin' Through the motor...
yonu
OK yeah I am getting water from them I guess I am just being paranoid as this is the first seapump I have installed in this out drive and the old one was horrable looking to the point the impeller was melted (used boat/drive)
w1bcr
try pulling the prop and puting the lower unit in a 55 gallon drum will cut down on mess
yonu
thanks that is what i wanted to findout.
thanks,
yonu
